Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Press down on the button located at the bottom of the phone, using the center ridge as a guide. Pull the phone apart from the bottom, keeping the button pressed down.
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Remove the back cover to expose the battery.
    • Remove the back cover to expose the battery.
  3. Place a finger or plastic opening tool in the gap between the battery and the phone. Gently lift the battery out.
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Locate the plastic latches on the left and right sides of the phone. Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  6. Remove the faceplate with the number pad attached.
    • Remove the faceplate with the number pad attached.
  7. Turn the faceplate so the number pad faces downward.
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  8. Locate the six screws positions along the edges of the motherboard. Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • Locate the six screws positions along the edges of the motherboard.
    • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • CAUTION! Place the screws in a secure location.
  9. Locate the orange ribbon tape connecting the metal display plate to the motherboard. Lift the black latch attaching the tape to the motherboard.
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  10. Using the plastic opening tool, gently pry off the motherboard from the plastic shell. CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  11. Gently pull the orange ribbon tape up to remove the display.
    • Gently pull the orange ribbon tape up to remove the display.
    • Replace display screen.
    • Follow the instructions in reverse order to reassemble the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ian VanZandt
600 İtibar
5 adet Kılavuz yazıldı
Takım
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 üyesi
JMU-KLEIN-S12S3G1
3 Üyeler
9 adet Kılavuz yazıldı
2 Yorum
Pretty accurate, nice guide! Easily repaired and it works!
Dominik Fryč - Yanıt
Perfect guide! But Where can i get original components??
Navin Singh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 4
Her zaman: 749
