Ana içeriğe geç
Nokia E61i Front Cover Replacement
Neye ihtiyacın var
  1. Nokia E61i Front Cover Replacement, Battery: adım 1, 2 resimden 1. Nokia E61i Front Cover Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Front Cover Replacement: adım 2, 1 resimden 1.
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Front Cover Replacement: adım 3, 1 resimden 1.
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Front Cover Replacement, Front Cover: adım 4, 2 resimden 1. Nokia E61i Front Cover Replacement, Front Cover: adım 4, 2 resimden 2.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Front Cover Replacement: adım 5, 1 resimden 1.
    • Remove the cover by pulling it up and off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Patton
208 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G63
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 2,880
