Ana içeriğe geç
Nokia E61i Motherboard Replacement
Neye ihtiyacın var
  1. Nokia E61i Motherboard Replacement, Battery: adım 1, 2 resimden 1. Nokia E61i Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Motherboard Replacement: adım 2, 1 resimden 1.
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Motherboard Replacement, Front Cover: adım 4, 2 resimden 1. Nokia E61i Motherboard Replacement, Front Cover: adım 4, 2 resimden 2.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Motherboard Replacement, Display: adım 6, 2 resimden 1. Nokia E61i Motherboard Replacement, Display: adım 6, 2 resimden 2.
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Motherboard Replacement: adım 7, 2 resimden 1. Nokia E61i Motherboard Replacement: adım 7, 2 resimden 2.
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Motherboard Replacement, Motherboard: adım 8, 3 resimden 1. Nokia E61i Motherboard Replacement, Motherboard: adım 8, 3 resimden 2. Nokia E61i Motherboard Replacement, Motherboard: adım 8, 3 resimden 3.
    • Pull the green motherboard from the back casing.
Sonuç
Christopher Patton
208 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G63
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,590
