Ana içeriğe geç
Nokia E62 Complete Disassembly
Neye ihtiyacın var
  1. Nokia E62 Complete Disassembly, Nokia E62 Complete Disassembly: adım 1, 1 resimden 1.
    • To start, press one of the latches at the top of the phone to open the rear cover.
  2. Nokia E62 Complete Disassembly: adım 2, 1 resimden 1.
    • Carefully press the other latch.
  3. Nokia E62 Complete Disassembly: adım 3, 1 resimden 1.
    • Open rear cover by this side.
  4. Nokia E62 Complete Disassembly: adım 4, 1 resimden 1.
    • Press the three latches to open this side of the cover.
  5. Nokia E62 Complete Disassembly: adım 5, 1 resimden 1.
    • Remove the rear cover.
  6. Nokia E62 Complete Disassembly: adım 6, 1 resimden 1.
    • Removed rear cover. See the latches .
  7. Nokia E62 Complete Disassembly: adım 7, 1 resimden 1.
    • Remove the screws using Torx T6 screw driver.
  8. Nokia E62 Complete Disassembly: adım 8, 1 resimden 1.
    • Remove six T6 screws.
  9. Nokia E62 Complete Disassembly: adım 9, 1 resimden 1.
    • Remove the assembly. The front cover will be released.
  10. Nokia E62 Complete Disassembly: adım 10, 1 resimden 1.
    • The front cover released.
  11. Nokia E62 Complete Disassembly: adım 11, 1 resimden 1.
    • To remove the display , unscrew the T6 Torx at top.
  12. Nokia E62 Complete Disassembly: adım 12, 1 resimden 1.
    • CAUTION! Remove the bottom screw with T5 Torx screw driver, not T6 !
  13. Nokia E62 Complete Disassembly: adım 13, 1 resimden 1.
    • Carefully disconnect the Flex cable connector. Then remove the display.
  14. Nokia E62 Complete Disassembly: adım 14, 1 resimden 1.
    • Carefully remove the adhesive keyboard membrane.
    • You can replace it at this step if you need to.
  15. Nokia E62 Complete Disassembly: adım 15, 1 resimden 1.
    • You can clean the keyboard surface with alcohol, if you dropped a drink here.
  16. Nokia E62 Complete Disassembly: adım 16, 1 resimden 1.
    • When you replace the keyboard membrane, align the two contacts at bottom.
  17. Nokia E62 Complete Disassembly: adım 17, 1 resimden 1.
    • You can wash the front cover and keyboard if they are dirty.
  18. Nokia E62 Complete Disassembly: adım 18, 1 resimden 1.
    • Keyboard - clean it if necessary.
  19. Nokia E62 Complete Disassembly: adım 19, 1 resimden 1.
    • Rear side of the circuit board.
  20. Nokia E62 Complete Disassembly: adım 20, 1 resimden 1.
    • Speaker and antenna contacts.
  21. Nokia E62 Complete Disassembly: adım 21, 1 resimden 1.
    • If necessary, you can replace the joystick, the button module or the connector housing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jose Gustavo Abreu Murta
4.970 İtibar
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 7,231
