Ana içeriğe geç
Nokia E71x Motherboard Replacement
Neye ihtiyacın var
  1. Nokia E71x Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Nokia E71x Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Remove battery
    FixBot'a Sor
    Yorum Ekle
  2. Nokia E71x Motherboard Replacement: adım 2, 1 resimden 1.
    • Using Torx number 4 unscrew the four 0.5mm screws.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia E71x Motherboard Replacement: adım 3, 1 resimden 1.
    • Push in four clips to detach the body.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia E71x Motherboard Replacement: adım 4, 3 resimden 1. Nokia E71x Motherboard Replacement: adım 4, 3 resimden 2. Nokia E71x Motherboard Replacement: adım 4, 3 resimden 3.
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia E71x Motherboard Replacement: adım 5, 3 resimden 1. Nokia E71x Motherboard Replacement: adım 5, 3 resimden 2. Nokia E71x Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia E71x Motherboard Replacement: adım 6, 1 resimden 1.
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia E71x Motherboard Replacement: adım 7, 2 resimden 1. Nokia E71x Motherboard Replacement: adım 7, 2 resimden 2.
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia E71x Motherboard Replacement: adım 8, 1 resimden 1.
    • Replace motherboard, ensure that replacement has the same serial number.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Will Goldby
187 İtibar
4 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-1, Zipperian Fall 2011 Cuesta, Team 1-1, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G1
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 3,615
