Ana içeriğe geç
Nokia E90 Battery Cover and Battery Replacement
  1. Nokia E90 Battery Cover and Battery Replacement, Battery Cover and Battery: adım 1, 1 resimden 1.
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 Battery Cover and Battery Replacement: adım 2, 2 resimden 1. Nokia E90 Battery Cover and Battery Replacement: adım 2, 2 resimden 2.
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 Battery Cover and Battery Replacement: adım 3, 1 resimden 1.
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
Sonuç
To reassemble the back cover, simply slide it back on.
Bir başkası bu kılavuzu tamamladı.
michael mira
14 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G21
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 5,356
