Ana içeriğe geç
Nokia E90 QWERTY Keyboard Replacement
Neye ihtiyacın var
  1. Nokia E90 QWERTY Keyboard Replacement, Battery Cover and Battery: adım 1, 1 resimden 1.
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 QWERTY Keyboard Replacement: adım 2, 2 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 2, 2 resimden 2.
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 QWERTY Keyboard Replacement: adım 3, 1 resimden 1.
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
  4. Nokia E90 QWERTY Keyboard Replacement, Back Cover: adım 4, 3 resimden 1. Nokia E90 QWERTY Keyboard Replacement, Back Cover: adım 4, 3 resimden 2. Nokia E90 QWERTY Keyboard Replacement, Back Cover: adım 4, 3 resimden 3.
    • Using a plastic opening tool, separate the back cover from the phone.
  5. Nokia E90 QWERTY Keyboard Replacement: adım 5, 2 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 5, 2 resimden 2.
    • Continue along the edge with the plastic opening tool.
  6. Nokia E90 QWERTY Keyboard Replacement: adım 6, 3 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 6, 3 resimden 2. Nokia E90 QWERTY Keyboard Replacement: adım 6, 3 resimden 3.
    • Gently, remove the back cover.
  7. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: adım 7, 3 resimden 1. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: adım 7, 3 resimden 2. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: adım 7, 3 resimden 3.
    • Unscrew the indicated screws using the T5 screwdriver.
  8. Nokia E90 QWERTY Keyboard Replacement: adım 8, 2 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 8, 2 resimden 2.
    • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
    • Be careful not to break the plastic during this step; do your best not to force anything.
  9. Nokia E90 QWERTY Keyboard Replacement: adım 9, 2 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 9, 2 resimden 2.
    • The button board will be loose once the cover is removed.
    • Lift it up to reveal the sensor board.
  10. Nokia E90 QWERTY Keyboard Replacement: adım 10, 2 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 10, 2 resimden 2.
    • With the T5 Screwdriver, remove the marked screws.
  11. Nokia E90 QWERTY Keyboard Replacement: adım 11, 2 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 11, 2 resimden 2.
    • With the screws removed, the sensor board should be free to flip up.
  12. Nokia E90 QWERTY Keyboard Replacement: adım 12, 2 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 12, 2 resimden 2.
    • Disconnect the wire with the plastic opening tool.
  13. Nokia E90 QWERTY Keyboard Replacement: adım 13, 3 resimden 1. Nokia E90 QWERTY Keyboard Replacement: adım 13, 3 resimden 2. Nokia E90 QWERTY Keyboard Replacement: adım 13, 3 resimden 3.
    • Remove the screws marked.
    • The Screw on the left is located underneath the cable.
    • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Cameron Weinberg
540 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G21
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 6,312
