Giriş
This guide will describe how to remove the motherboard of your Nokia Lumia 1020.
This replacement will be useful if you want to replace a damaged motherboard or upgrade from your current motherboard. Upgrading your motherboard can result in faster performance and better graphics. If you are experiencing significant delays in your phone performance, you may want to consider upgrading your motherboard.
Neye ihtiyacın var
Use a SIM door key to remove the SIM card and SIM card tray from the device.
Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
Gently pry the screen away from the back of the device using slight upward pressure.
Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
Bu adımda kullanılan alet:Tweezers$4.99
Unscrew the two 4 mm torx screws on the top silver strip with a T4 screwdriver.
Unscrew the 4.5 mm torx screw above the gold bar with a T6 screwdriver.
Grab the edges of the gold strip with gripped tweezers to remove. The gold and silver metal will come off together.
Use the T4 screwdriver to remove the 4 mm torx screw.
Remove the headphone jack by pulling back on the silver plate with your fingernail.
Use your fingernail to grip the rear-facing camera on the upper middle part of the back of the phone. Pry until it pops off to the left.
Remove the camera by wedging a spudger underneath the attached gold foil.
Disconnect the two gold connectors from the motherboard using a spudger.
