Giriş
Battery draining quickly? It may be time for a new one. Use this guide to help you replace your phone's battery.
Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
2 farklı kişi bu kılavuzu tamamladı.
One Comment
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
