Ana içeriğe geç
Nokia Lumia 521 Audio Jack Replacement
Neye ihtiyacın var
  1. Nokia Lumia 521 Audio Jack Replacement, Battery: adım 1, 2 resimden 1. Nokia Lumia 521 Audio Jack Replacement, Battery: adım 1, 2 resimden 2.
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 Audio Jack Replacement: adım 2, 1 resimden 1.
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 Audio Jack Replacement, SIM Card: adım 3, 1 resimden 1.
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
  4. Nokia Lumia 521 Audio Jack Replacement, Motherboard: adım 4, 2 resimden 1. Nokia Lumia 521 Audio Jack Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using the Torx T5 screw head, remove all screws. Note that there are two different sized screws. Five screws are 5 mm long and four are 4 mm long.
    • Five 5 mm screws.
    • Four 4 mm screws.
  5. Nokia Lumia 521 Audio Jack Replacement: adım 5, 2 resimden 1. Nokia Lumia 521 Audio Jack Replacement: adım 5, 2 resimden 2.
    • Using a plastic opening tool, pry apart the inner back case apart from the rest of the phone, starting at the top and prying while going around the phone.
  6. Nokia Lumia 521 Audio Jack Replacement: adım 6, 2 resimden 1. Nokia Lumia 521 Audio Jack Replacement: adım 6, 2 resimden 2.
    • Unclasp the motherboard from the black case clasps using a plastic opening tool.
  7. Nokia Lumia 521 Audio Jack Replacement: adım 7, 2 resimden 1. Nokia Lumia 521 Audio Jack Replacement: adım 7, 2 resimden 2.
    • Unclip the motherboard clasps using your fingers or a plastic opening tool.
  8. Nokia Lumia 521 Audio Jack Replacement, Audio Jack: adım 8, 1 resimden 1.
    • Use the plastic opening tool to pry the audio jack loose.
  9. Nokia Lumia 521 Audio Jack Replacement: adım 9, 1 resimden 1.
    • After prying the audio jack loose, use the plastic opening tool to remove the connective tab.
Sonuç
Selamawi Ambaye
261 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Sullivan Spring 2016 USF Tampa, Team 2-4, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 305
