Ana içeriğe geç
Nokia Lumia 521 SIM Card Replacement
Neye ihtiyacın var
  1. Nokia Lumia 521 SIM Card Replacement, Battery: adım 1, 2 resimden 1. Nokia Lumia 521 SIM Card Replacement, Battery: adım 1, 2 resimden 2.
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 SIM Card Replacement: adım 2, 1 resimden 1.
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 SIM Card Replacement, SIM Card: adım 3, 1 resimden 1.
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
Sonuç
Marko Stanisic
322 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Sullivan Spring 2016 USF Tampa, Team 2-4, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G4
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 1,639
