Ana içeriğe geç
Nokia Lumia 620 Volume and Power Button Replacement
Neye ihtiyacın var
  1. Nokia Lumia 620 Volume and Power Button Replacement, Volume and Power Button: adım 1, 1 resimden 1.
    • Check condition of switches on logicboard
    • Rule out failure of cover
  2. Nokia Lumia 620 Volume and Power Button Replacement: adım 2, 1 resimden 1.
    • Torx 6 screwdriver
    • Soldering iron (thin tip)
    • Decent quality solder (thin wire)
  3. Nokia Lumia 620 Volume and Power Button Replacement: adım 3, 1 resimden 1.
    • Remove cover, battery and SIM
    • Remove 6 torx screws
    • Note: Green is fine thread
    • Note: Red is coarse thread
  4. Nokia Lumia 620 Volume and Power Button Replacement: adım 4, 2 resimden 1. Nokia Lumia 620 Volume and Power Button Replacement: adım 4, 2 resimden 2.
    • Remove plastic clover near battery
    • Keep track of all parts
  5. Nokia Lumia 620 Volume and Power Button Replacement: adım 5, 1 resimden 1.
    • Gently release logicboard connectors
  6. Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: adım 6, 2 resimden 1. Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: adım 6, 2 resimden 2.
    • There is a clip that needs to be moved out of the way before the board will move.
    • Start by lifting long side of logicboard
    • Gently wiggle and lift
    • Undo plastic clips near battery with force
  7. Nokia Lumia 620 Volume and Power Button Replacement: adım 7, 1 resimden 1.
    • Check connections of failed buttons
  8. Nokia Lumia 620 Volume and Power Button Replacement: adım 8, 1 resimden 1.
    • Resolder broken connections
    • Make sure the pads do not short
  9. Nokia Lumia 620 Volume and Power Button Replacement: adım 9, 1 resimden 1.
    • Put back logicboard
    • Make sure pins near camera line-up
    • Note: Plastic clips need quite some force
  10. Nokia Lumia 620 Volume and Power Button Replacement: adım 10, 1 resimden 1.
    • Reconnect logicboard connectors
  11. Nokia Lumia 620 Volume and Power Button Replacement: adım 11, 1 resimden 1.
    • Put back plastic cover
  12. Nokia Lumia 620 Volume and Power Button Replacement: adım 12, 1 resimden 1.
    • Gently tighten screws
    • Put back SIM card and battery
    • Close cover
    • Enjoy the result ;)
Bitiş Çizgisi
11 farklı kişi bu kılavuzu tamamladı.
Anne
456 İtibar
1 Kılavuz yazıldı
4 Yorum
Realmente funcionó el tutorial, sirven de nuevo los dos botones que fallaban.
Gaia501 - Yanıt
Only the 2 middle screws are fine threaded. And you can see in the pictures here, that there are 4 coarse threaded ones and 2 fine threaded ones. The green one in the corner should be red
shadow118 - Yanıt
hafıza kart okuyucu çalışmıyor ne yapmam lazım
davutcigir - Yanıt
Omg it looks complicated
Maz Hanvey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 10,178
