Ana içeriğe geç
Nokia Lumia 635 630 Display Assembly Replacement with Frame
Neye ihtiyacın var
Videoya Genel Bakış
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: adım 1, 3 resimden 1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: adım 1, 3 resimden 2. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: adım 1, 3 resimden 3.
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: adım 2, 3 resimden 1. Nokia Lumia 635 630 Display Assembly Replacement with Frame: adım 2, 3 resimden 2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: adım 2, 3 resimden 3.
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: adım 3, 3 resimden 1. Nokia Lumia 635 630 Display Assembly Replacement with Frame: adım 3, 3 resimden 2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: adım 3, 3 resimden 3.
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: adım 4, 3 resimden 1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: adım 4, 3 resimden 2. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: adım 4, 3 resimden 3.
    • Put the earpiece on the new display assembly and start with reassembling.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
2 Yorum
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - Yanıt
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 10,324
