Ana içeriğe geç
Nokia Lumia 635 Display Assembly Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: adım 1, 3 resimden 1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: adım 1, 3 resimden 2. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: adım 1, 3 resimden 3.
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory cards.
    • Remove the black tape near to the loudspeaker.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: adım 2, 3 resimden 1. Nokia Lumia 635 Display Assembly Replacement, SCREWS: adım 2, 3 resimden 2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: adım 2, 3 resimden 3.
    • Remove the 9x Torx T4 screws.
    • Two of them are with the same head size but with a different length.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: adım 3, 3 resimden 1. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: adım 3, 3 resimden 2. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: adım 3, 3 resimden 3.
    • Use a plastic opening tool to remove the back cover.
    • Careful unhook the display assembly flex cable.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: adım 4, 3 resimden 1. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: adım 4, 3 resimden 2. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: adım 4, 3 resimden 3.
    • Insert wisdom here.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: adım 5, 2 resimden 1. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: adım 5, 2 resimden 2.
    • Put some scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: adım 6, 3 resimden 1. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: adım 6, 3 resimden 2. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: adım 6, 3 resimden 3.
    • Start the separating from the upper right corner, where you have an hole in the middle frame.
    • Use plastic tool to prevent the middle frame from scratches.
    • Work slowly, you can cut your fingers.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: adım 7, 3 resimden 1. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: adım 7, 3 resimden 2. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: adım 7, 3 resimden 3.
    • Clean the middle farme.
    • Put adhesive tape 3MM.
    • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
    • It's easier if you order the spare part together with an adhesive tape.
    • Install the display assembly.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia Lumia 635 Display Assembly Replacement: adım 8, 2 resimden 1. Nokia Lumia 635 Display Assembly Replacement: adım 8, 2 resimden 2.
    • That's all.
    • Did you do it successfully?
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ZFix
197.270 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
334 Üyeler
1.701 adet Kılavuz yazıldı
2Kılavuz Yorumları
Exactly what I needed! Step by step detailed instructions along with what tools I would need. Heating it up took longer than expected & it took me longer than 30 min, but I actually set aside 2 hours to replace my screen. Woohoo I finally I have a new screen & I did it all on my own...well with the amazing help from ZFix ;D
beatriz_ibre - Yanıt Paylaş
how to fix the display
Roneil Mcintosh - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 10,560
