Ana içeriğe geç
Nokia Lumia 635 Motherboard Replacement
Neye ihtiyacın var
  1. Nokia Lumia 635 Motherboard Replacement, Battery Removal: adım 1, 2 resimden 1. Nokia Lumia 635 Motherboard Replacement, Battery Removal: adım 1, 2 resimden 2.
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Motherboard Replacement, Screw Removal: adım 2, 2 resimden 1. Nokia Lumia 635 Motherboard Replacement, Screw Removal: adım 2, 2 resimden 2.
    • Remove the five screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Motherboard Replacement, Remove Hidden Screw: adım 3, 1 resimden 1.
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Motherboard Replacement, Separating Back Cover From Screen: adım 4, 1 resimden 1.
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex cable attached to the mother board, watch out when separating them.
  5. Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: adım 5, 3 resimden 1. Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: adım 5, 3 resimden 2. Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: adım 5, 3 resimden 3.
    • Carefully retrieve the camera and audio jack’s flex that is attached to the mother board as shown in the picture.
    • Retrieve the burnt Mother Board and replace it with the new one.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Daniel Robles
828 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-1, Leahy Fall 2014 USF Tampa, Team 7-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G1
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 9,081
