Ana içeriğe geç
Nokia Lumia 635 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Nokia Lumia 635 Rear Facing Camera Replacement, Get Started - Open phone case: adım 1, 2 resimden 1. Nokia Lumia 635 Rear Facing Camera Replacement, Get Started - Open phone case: adım 1, 2 resimden 2.
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Rear Facing Camera Replacement, Screw removal: adım 2, 2 resimden 1. Nokia Lumia 635 Rear Facing Camera Replacement, Screw removal: adım 2, 2 resimden 2.
    • Remove the six screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Rear Facing Camera Replacement, Remove hidden screw: adım 3, 1 resimden 1.
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Rear Facing Camera Replacement, Separating Back Cover From Screen: adım 4, 1 resimden 1.
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
  5. Nokia Lumia 635 Rear Facing Camera Replacement, Camera Replacement: adım 5, 1 resimden 1.
    • Carefully retrieve the cameras flex as shown in the picture.
    • Attach the new camera’s flex to the mother board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alexa
455 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 7-1, Leahy Fall 2014 USF Tampa, Team 7-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G1
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 2,153
