Ana içeriğe geç
Nokia Lumia 720 Coaxial Antenna Cable Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 1: adım 1, 3 resimden 1. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 1: adım 1, 3 resimden 2. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 1: adım 1, 3 resimden 3.
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 2: adım 2, 3 resimden 1. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 2: adım 2, 3 resimden 2. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 2: adım 2, 3 resimden 3.
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Coaxial Antenna Cable Replacement, Loudspeaker & Antenna module: adım 3, 3 resimden 1. Nokia Lumia 720 Coaxial Antenna Cable Replacement, Loudspeaker & Antenna module: adım 3, 3 resimden 2. Nokia Lumia 720 Coaxial Antenna Cable Replacement, Loudspeaker & Antenna module: adım 3, 3 resimden 3.
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Coaxial Antenna Cable Replacement, COAXIAL ANTENNA CABLE: adım 4, 3 resimden 1. Nokia Lumia 720 Coaxial Antenna Cable Replacement, COAXIAL ANTENNA CABLE: adım 4, 3 resimden 2. Nokia Lumia 720 Coaxial Antenna Cable Replacement, COAXIAL ANTENNA CABLE: adım 4, 3 resimden 3.
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
Sonuç
ZFix
194.072 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.697 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 933
