Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Nokia Lumia 830 Battery Replacement
Neye ihtiyacın var
  1. Nokia Lumia 830 Battery Replacement, Battery: adım 1, 2 resimden 1. Nokia Lumia 830 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Place the phone with the screen facing down.
    • Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
  2. Nokia Lumia 830 Battery Replacement: adım 2, 3 resimden 1. Nokia Lumia 830 Battery Replacement: adım 2, 3 resimden 2. Nokia Lumia 830 Battery Replacement: adım 2, 3 resimden 3.
    • Carefully remove the battery by placing the plastic opening tool underneath the indent at the bottom of the battery, and pry it up.
    • There may be adhesive underneath the battery to keep it in place, this may make it a bit difficult to remove the battery.
Sonuç
Adam Mack
284 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Sullivan Fall 2016 USF Tampa, Team 1-2, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S1G2
3 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Hi, i’ve bought a battery from amazon to this phone. It has the same specs as the old one, but when i put it to charge (on the phone) it only charges untill half and it stays there. Do i need to buy a different battery or is there a way to fix this?
Eduardo Teixeira - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,399
