Ana içeriğe geç
Nokia Lumia 900 Front Camera Replacement
Neye ihtiyacın var
  1. Nokia Lumia 900 Front Camera Replacement, Screen: adım 1, 2 resimden 1. Nokia Lumia 900 Front Camera Replacement, Screen: adım 1, 2 resimden 2.
    • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
  2. Nokia Lumia 900 Front Camera Replacement: adım 2, 2 resimden 1. Nokia Lumia 900 Front Camera Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the small rod in the port indicated in the picture.
  3. Nokia Lumia 900 Front Camera Replacement: adım 3, 2 resimden 1. Nokia Lumia 900 Front Camera Replacement: adım 3, 2 resimden 2.
    • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
  4. Nokia Lumia 900 Front Camera Replacement: adım 4, 2 resimden 1. Nokia Lumia 900 Front Camera Replacement: adım 4, 2 resimden 2.
    • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
  5. Nokia Lumia 900 Front Camera Replacement: adım 5, 1 resimden 1.
    • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
    • Remove the screen.
  6. Nokia Lumia 900 Front Camera Replacement, Front Camera: adım 6, 2 resimden 1. Nokia Lumia 900 Front Camera Replacement, Front Camera: adım 6, 2 resimden 2.
    • Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
    • Use the plastic opening tools to carefully lift the front camera from the motherboard.
Sonuç
Kourtney Collier
289 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Spring 2022 IUPUI, Team 3-2, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 116
