Ana içeriğe geç
Nokia Lumia 900 Speaker Replacement
Neye ihtiyacın var
  1. Nokia Lumia 900 Speaker Replacement, Screen: adım 1, 2 resimden 1. Nokia Lumia 900 Speaker Replacement, Screen: adım 1, 2 resimden 2.
    • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
  2. Nokia Lumia 900 Speaker Replacement: adım 2, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 2, 2 resimden 2.
    • Use tweezers to remove the small rod in the port indicated in the picture.
  3. Nokia Lumia 900 Speaker Replacement: adım 3, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 3, 2 resimden 2.
    • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
  4. Nokia Lumia 900 Speaker Replacement: adım 4, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 4, 2 resimden 2.
    • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
  5. Nokia Lumia 900 Speaker Replacement: adım 5, 1 resimden 1.
    • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
    • Remove the screen.
  6. Nokia Lumia 900 Speaker Replacement, Front Camera: adım 6, 2 resimden 1. Nokia Lumia 900 Speaker Replacement, Front Camera: adım 6, 2 resimden 2.
    • Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
    • Use the plastic opening tools to carefully lift the front camera from the motherboard.
  7. Nokia Lumia 900 Speaker Replacement, Battery: adım 7, 2 resimden 1. Nokia Lumia 900 Speaker Replacement, Battery: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to carefully disconnect the ribbon cable.
    • Make sure not to bend or crease the cable.
  8. Nokia Lumia 900 Speaker Replacement: adım 8, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to remove the battery.
    • The battery may be glued down. This will be evident if the battery is difficult to lift. Use the iFixit iOpener to heat the back of the phone allowing the glue to heat and become more pliable before trying to lift the battery again. This may take several minutes.
  9. Nokia Lumia 900 Speaker Replacement, Speaker: adım 9, 2 resimden 1. Nokia Lumia 900 Speaker Replacement, Speaker: adım 9, 2 resimden 2.
    • Use the plastic opening tool to lift the orange ribbon cable from the motherboard.
  10. Nokia Lumia 900 Speaker Replacement: adım 10, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 10, 2 resimden 2.
    • Use the plastic opening tool to lift the motherboard out of the casing.
    • It is recommended that you wedge the opening tool in the crevice between the motherboard and casing in the top righthand corner of the device.
  11. Nokia Lumia 900 Speaker Replacement: adım 11, 1 resimden 1.
    • Use the flat end of a spudger to lift the LED out of the casing.
  12. Nokia Lumia 900 Speaker Replacement: adım 12, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 12, 2 resimden 2.
    • Use the flat end of a spudger to lift the metal backplate from the casing.
    • Be sure not to lose the buttons.
  13. Nokia Lumia 900 Speaker Replacement: adım 13, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 13, 2 resimden 2.
    • Wedge the pointed end of the spudger into the gaps in the antenna housing and pull the antenna housing away from the casing walls.
  14. Nokia Lumia 900 Speaker Replacement: adım 14, 2 resimden 1. Nokia Lumia 900 Speaker Replacement: adım 14, 2 resimden 2.
    • Insert the pointed end of the spudger into the hole and slide the speaker housing out from the casing.
Sonuç
Kourtney Collier
289 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Spring 2022 IUPUI, Team 3-2, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 103
