Ana içeriğe geç
Nokia Lumia 920 Back panel Replacement
Neye ihtiyacın var
  1. Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: adım 1, 3 resimden 1. Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: adım 1, 3 resimden 2. Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: adım 1, 3 resimden 3.
    • Make sure the phone is off.
    • Use the T5 screwdriver to remove the two 8.6mm long screws, located at the bottom of the phone. (Head size is 2.5mm)
  2. Nokia Lumia 920 Back panel Replacement: adım 2, 2 resimden 1. Nokia Lumia 920 Back panel Replacement: adım 2, 2 resimden 2.
    • Use the smallest Torx screwdriver or another small poking tool and push into the hole on the SIM card slot. The plastic SIM protective piece should pop out quite easily.
    • Put that plastic piece aside.
  3. Nokia Lumia 920 Back panel Replacement: adım 3, 2 resimden 1. Nokia Lumia 920 Back panel Replacement: adım 3, 2 resimden 2.
    • Once both screws on the bottom are removed, and the plastic SIM protective piece is removed, gently push on the outside of the screen.
    • The screen should become separated using little force. And should like the pictures shown once complete.
  4. Nokia Lumia 920 Back panel Replacement: adım 4, 2 resimden 1. Nokia Lumia 920 Back panel Replacement: adım 4, 2 resimden 2.
    • This step may be easier to remove the battery first, but it is not mandatory.
    • Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
    • Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
  5. Nokia Lumia 920 Back panel Replacement: adım 5, 2 resimden 1. Nokia Lumia 920 Back panel Replacement: adım 5, 2 resimden 2.
    • Once the metal clip is removed, gently pry up on the ribbon cable connection, located underneath the metal clip you have just removed.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Jonathan
1.492 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Miles Fall 2014 UMass Dartmouth, Team 4-2, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G2
2 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
useless - doesnt show detail
nick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 9,392
