Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Nokia Lumia 925 Motherboard Replacement
Neye ihtiyacın var
  1. Nokia Lumia 925 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Nokia Lumia 925 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Motherboard Replacement: adım 2, 3 resimden 1. Nokia Lumia 925 Motherboard Replacement: adım 2, 3 resimden 2. Nokia Lumia 925 Motherboard Replacement: adım 2, 3 resimden 3.
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Motherboard Replacement: adım 3, 3 resimden 1. Nokia Lumia 925 Motherboard Replacement: adım 3, 3 resimden 2. Nokia Lumia 925 Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Motherboard Replacement: adım 4, 2 resimden 1. Nokia Lumia 925 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the silver metal cover.
  5. Nokia Lumia 925 Motherboard Replacement: adım 5, 3 resimden 1. Nokia Lumia 925 Motherboard Replacement: adım 5, 3 resimden 2. Nokia Lumia 925 Motherboard Replacement: adım 5, 3 resimden 3.
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Motherboard Replacement: adım 6, 2 resimden 1. Nokia Lumia 925 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 748
