Ana içeriğe geç
Nokia Lumia 930 Battery Replacement
Neye ihtiyacın var
    1. Nokia Lumia 930 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Pull the SIM card holder out of the top of the phone using your fingernail.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia Lumia 930 Battery Replacement: adım 2, 2 resimden 1. Nokia Lumia 930 Battery Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
      FixBot'a Sor
      Yorum Ekle
    3. Nokia Lumia 930 Battery Replacement: adım 3, 2 resimden 1. Nokia Lumia 930 Battery Replacement: adım 3, 2 resimden 2.
      • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
      FixBot'a Sor
      Yorum Ekle
    4. Nokia Lumia 930 Battery Replacement: adım 4, 1 resimden 1.
      • Remove the 4mm Torx #4 screw that's securing the battery connector.
      FixBot'a Sor
      Yorum Ekle
    5. Nokia Lumia 930 Battery Replacement: adım 5, 1 resimden 1.
      • Use tweezers to remove the battery connector strap.
      FixBot'a Sor
      Yorum Ekle
    6. Nokia Lumia 930 Battery Replacement: adım 6, 2 resimden 1. Nokia Lumia 930 Battery Replacement: adım 6, 2 resimden 2.
      • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
      FixBot'a Sor
      Yorum Ekle
    7. Nokia Lumia 930 Battery Replacement: adım 7, 3 resimden 1. Nokia Lumia 930 Battery Replacement: adım 7, 3 resimden 2. Nokia Lumia 930 Battery Replacement: adım 7, 3 resimden 3.
      • Use the flat end of a spudger to pry the battery cover from the phone's frame.
      FixBot'a Sor
      Yorum Ekle
    8. Nokia Lumia 930 Battery Replacement: adım 8, 1 resimden 1.
      • Pull up on the heat spreader.
      • Be careful not to tear it!
      FixBot'a Sor
      Yorum Ekle
    9. Nokia Lumia 930 Battery Replacement: adım 9, 1 resimden 1.
      • Use the flat end of the spudger to lift up the battery.
      • The battery is glued in place. Pry up carefully, not to damage it.
      • Two flex cables are directly underneath the battery.
      FixBot'a Sor
      Yorum Ekle
    10. Nokia Lumia 930 Battery Replacement: adım 10, 1 resimden 1.
      • Remove the battery from the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 20
Son 30 gün: 85
Her zaman: 6,911
