Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
In this guide you will learn to remove the LCD screen of your Nokia Lumia 930. The LCD screen is the panel inside of your device that displays images.
Neye ihtiyacın var
Use the flat end of a spudger to disconnect the camera connectors.
Pull the camera up and out to remove it from the phone.
Use the pointed end of the spudger to pry up the daughterboard.
Use tweezers to lift the daughterboard out of the phone.
Place the suction cup in the middle of your screen and pry away from the frame.
2 farklı kişi bu kılavuzu tamamladı.
