Ana içeriğe geç
Nokia Lumia 930 Microphone Removal
Neye ihtiyacın var
  1. Nokia Lumia 930 Microphone Removal, Battery: adım 1, 1 resimden 1.
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Microphone Removal: adım 2, 2 resimden 1. Nokia Lumia 930 Microphone Removal: adım 2, 2 resimden 2.
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Microphone Removal: adım 3, 2 resimden 1. Nokia Lumia 930 Microphone Removal: adım 3, 2 resimden 2.
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Microphone Removal: adım 4, 1 resimden 1.
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Microphone Removal: adım 5, 1 resimden 1.
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Microphone Removal: adım 6, 2 resimden 1. Nokia Lumia 930 Microphone Removal: adım 6, 2 resimden 2.
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Microphone Removal: adım 7, 3 resimden 1. Nokia Lumia 930 Microphone Removal: adım 7, 3 resimden 2. Nokia Lumia 930 Microphone Removal: adım 7, 3 resimden 3.
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Microphone Removal: adım 8, 1 resimden 1.
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Microphone Removal: adım 9, 1 resimden 1.
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Microphone Removal: adım 10, 1 resimden 1.
    • Remove the battery from the phone.
  11. Nokia Lumia 930 Microphone Removal, Motherboard: adım 11, 2 resimden 1. Nokia Lumia 930 Microphone Removal, Motherboard: adım 11, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the camera connectors.
    • Pull the camera up and out to remove it from the phone.
  12. Nokia Lumia 930 Microphone Removal: adım 12, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
  13. Nokia Lumia 930 Microphone Removal: adım 13, 3 resimden 1. Nokia Lumia 930 Microphone Removal: adım 13, 3 resimden 2. Nokia Lumia 930 Microphone Removal: adım 13, 3 resimden 3.
    • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
    • Remove the orange flex cable from the phone.
  14. Nokia Lumia 930 Microphone Removal: adım 14, 1 resimden 1.
    • Repeat the previous step for the black jumper flex cable under the battery.
  15. Nokia Lumia 930 Microphone Removal: adım 15, 2 resimden 1. Nokia Lumia 930 Microphone Removal: adım 15, 2 resimden 2.
    • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
    • Remove the antenna.
  16. Nokia Lumia 930 Microphone Removal: adım 16, 1 resimden 1.
    • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
    • Apply new adhesive when reassembling the phone.
  17. Nokia Lumia 930 Microphone Removal: adım 17, 3 resimden 1. Nokia Lumia 930 Microphone Removal: adım 17, 3 resimden 2. Nokia Lumia 930 Microphone Removal: adım 17, 3 resimden 3.
    • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
  18. Nokia Lumia 930 Microphone Removal, Daughterboard: adım 18, 2 resimden 1. Nokia Lumia 930 Microphone Removal, Daughterboard: adım 18, 2 resimden 2.
    • Use the pointed end of the spudger to pry up the daughterboard.
    • Use tweezers to lift the daughterboard out of the phone.
  19. Nokia Lumia 930 Microphone Removal, Nokia Lumia 930 Microphone Removal: adım 19, 3 resimden 1. Nokia Lumia 930 Microphone Removal, Nokia Lumia 930 Microphone Removal: adım 19, 3 resimden 2. Nokia Lumia 930 Microphone Removal, Nokia Lumia 930 Microphone Removal: adım 19, 3 resimden 3.
    • Locate all microphones. The first two microphones you will find are on the engine board. The two microphones will be back to back with each other. The third microphone will be on the engine cover. The last microphone will be on the last layer of the phone before the screen.
  20. Nokia Lumia 930 Microphone Removal: adım 20, 2 resimden 1. Nokia Lumia 930 Microphone Removal: adım 20, 2 resimden 2.
    • You are gonna wanna use akistan to pop off the microphone.
    • Remove all remainings with the Spudger #2.
    • Repeat both steps on second microphone which is located on the other side of the first microphone.
    • Be gentle with the metal akistan it is stronger than the Spudger.
  21. Nokia Lumia 930 Microphone Removal: adım 21, 1 resimden 1.
    • Use spudger to remove 3rd microphone. Located on the engine board cover.
  22. Nokia Lumia 930 Microphone Removal: adım 22, 1 resimden 1.
    • Use spudger to remove 3rd microphone. Located on the last layer before the display screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 652
