Ana içeriğe geç
Nokia Lumia 930 Motherboard Replacement
Neye ihtiyacın var
  1. Nokia Lumia 930 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Motherboard Replacement: adım 2, 2 resimden 1. Nokia Lumia 930 Motherboard Replacement: adım 2, 2 resimden 2.
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Motherboard Replacement: adım 3, 2 resimden 1. Nokia Lumia 930 Motherboard Replacement: adım 3, 2 resimden 2.
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Motherboard Replacement: adım 6, 2 resimden 1. Nokia Lumia 930 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Motherboard Replacement: adım 7, 3 resimden 1. Nokia Lumia 930 Motherboard Replacement: adım 7, 3 resimden 2. Nokia Lumia 930 Motherboard Replacement: adım 7, 3 resimden 3.
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Motherboard Replacement: adım 9, 1 resimden 1.
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the battery from the phone.
  11. Nokia Lumia 930 Motherboard Replacement, Motherboard: adım 11, 2 resimden 1. Nokia Lumia 930 Motherboard Replacement, Motherboard: adım 11, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the camera connectors.
    • Pull the camera up and out to remove it from the phone.
  12. Nokia Lumia 930 Motherboard Replacement: adım 12, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
  13. Nokia Lumia 930 Motherboard Replacement: adım 13, 3 resimden 1. Nokia Lumia 930 Motherboard Replacement: adım 13, 3 resimden 2. Nokia Lumia 930 Motherboard Replacement: adım 13, 3 resimden 3.
    • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
    • Remove the orange flex cable from the phone.
  14. Nokia Lumia 930 Motherboard Replacement: adım 14, 1 resimden 1.
    • Repeat the previous step for the black jumper flex cable under the battery.
  15. Nokia Lumia 930 Motherboard Replacement: adım 15, 2 resimden 1. Nokia Lumia 930 Motherboard Replacement: adım 15, 2 resimden 2.
    • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
    • Remove the antenna.
  16. Nokia Lumia 930 Motherboard Replacement: adım 16, 1 resimden 1.
    • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
    • Apply new adhesive when reassembling the phone.
  17. Nokia Lumia 930 Motherboard Replacement: adım 17, 3 resimden 1. Nokia Lumia 930 Motherboard Replacement: adım 17, 3 resimden 2. Nokia Lumia 930 Motherboard Replacement: adım 17, 3 resimden 3.
    • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,089
