Ana içeriğe geç
Nokia Lumia 930 Vibration Module Replacement
Neye ihtiyacın var
    1. Nokia Lumia 930 Vibration Module Replacement, Battery: adım 1, 1 resimden 1.
      • Pull the SIM card holder out of the top of the phone using your fingernail.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia Lumia 930 Vibration Module Replacement: adım 2, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
      FixBot'a Sor
      Yorum Ekle
    3. Nokia Lumia 930 Vibration Module Replacement: adım 3, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 3, 2 resimden 2.
      • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
      FixBot'a Sor
      Yorum Ekle
    4. Nokia Lumia 930 Vibration Module Replacement: adım 4, 1 resimden 1.
      • Remove the 4mm Torx #4 screw that's securing the battery connector.
      FixBot'a Sor
      Yorum Ekle
    5. Nokia Lumia 930 Vibration Module Replacement: adım 5, 1 resimden 1.
      • Use tweezers to remove the battery connector strap.
      FixBot'a Sor
      Yorum Ekle
    6. Nokia Lumia 930 Vibration Module Replacement: adım 6, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 6, 2 resimden 2.
      • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
      FixBot'a Sor
      Yorum Ekle
    7. Nokia Lumia 930 Vibration Module Replacement: adım 7, 3 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 7, 3 resimden 2. Nokia Lumia 930 Vibration Module Replacement: adım 7, 3 resimden 3.
      • Use the flat end of a spudger to pry the battery cover from the phone's frame.
      FixBot'a Sor
      Yorum Ekle
    8. Nokia Lumia 930 Vibration Module Replacement: adım 8, 1 resimden 1.
      • Pull up on the heat spreader.
      • Be careful not to tear it!
      FixBot'a Sor
      Yorum Ekle
    9. Nokia Lumia 930 Vibration Module Replacement: adım 9, 1 resimden 1.
      • Use the flat end of the spudger to lift up the battery.
      • The battery is glued in place. Pry up carefully, not to damage it.
      • Two flex cables are directly underneath the battery.
      FixBot'a Sor
      Yorum Ekle
    10. Nokia Lumia 930 Vibration Module Replacement: adım 10, 1 resimden 1.
      • Remove the battery from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia Lumia 930 Vibration Module Replacement, Motherboard: adım 11, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement, Motherboard: adım 11, 2 resimden 2.
      • Use the flat end of a spudger to disconnect the camera connectors.
      • Pull the camera up and out to remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia Lumia 930 Vibration Module Replacement: adım 12, 1 resimden 1.
      • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Nokia Lumia 930 Vibration Module Replacement: adım 13, 3 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 13, 3 resimden 2. Nokia Lumia 930 Vibration Module Replacement: adım 13, 3 resimden 3.
      • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
      • Remove the orange flex cable from the phone.
      FixBot'a Sor
      Yorum Ekle
    4. Nokia Lumia 930 Vibration Module Replacement: adım 14, 1 resimden 1.
      • Repeat the previous step for the black jumper flex cable under the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Nokia Lumia 930 Vibration Module Replacement: adım 15, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 15, 2 resimden 2.
      • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
      • Remove the antenna.
      FixBot'a Sor
      Yorum Ekle
    6. Nokia Lumia 930 Vibration Module Replacement: adım 16, 1 resimden 1.
      • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
      • Apply new adhesive when reassembling the phone.
      FixBot'a Sor
      Yorum Ekle
    7. Nokia Lumia 930 Vibration Module Replacement: adım 17, 3 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 17, 3 resimden 2. Nokia Lumia 930 Vibration Module Replacement: adım 17, 3 resimden 3.
      • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia Lumia 930 Vibration Module Replacement, Daughterboard: adım 18, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement, Daughterboard: adım 18, 2 resimden 2.
      • Use the pointed end of the spudger to pry up the daughterboard.
      • Use tweezers to lift the daughterboard out of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia Lumia 930 Vibration Module Replacement, Vibration Module: adım 19, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement, Vibration Module: adım 19, 2 resimden 2.
      • Use a pair of tweezers to remove the vibration boot that covers the module.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia Lumia 930 Vibration Module Replacement: adım 20, 1 resimden 1.
      • Use the flat end of the spudger to lift the module off of the adhesive.
      • Be delicate so that you don't break off the rotating piece of the module.
      FixBot'a Sor
      Yorum Ekle
    3. Nokia Lumia 930 Vibration Module Replacement: adım 21, 2 resimden 1. Nokia Lumia 930 Vibration Module Replacement: adım 21, 2 resimden 2.
      • Use tweezers to continually lift the module and flex up off of the adhesive.
      • Pull up until the vibration module is completely removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 623
