Ana içeriğe geç
Nokia N70 Display Replacement
Neye ihtiyacın var
  1. Nokia N70 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia N70 Display Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover by lifting it away from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia N70 Display Replacement: adım 3, 1 resimden 1.
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia N70 Display Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia N70 Display Replacement, Keypad: adım 5, 3 resimden 1. Nokia N70 Display Replacement, Keypad: adım 5, 3 resimden 2. Nokia N70 Display Replacement, Keypad: adım 5, 3 resimden 3.
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia N70 Display Replacement: adım 6, 3 resimden 1. Nokia N70 Display Replacement: adım 6, 3 resimden 2. Nokia N70 Display Replacement: adım 6, 3 resimden 3.
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia N70 Display Replacement, Display: adım 7, 1 resimden 1.
    • Using a torx T6 screwdriver remove the six 15 mm torx screws.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia N70 Display Replacement: adım 8, 2 resimden 1. Nokia N70 Display Replacement: adım 8, 2 resimden 2.
    • Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia N70 Display Replacement: adım 9, 2 resimden 1. Nokia N70 Display Replacement: adım 9, 2 resimden 2.
    • Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect.
    • Remove the ribbon connection that connects the two circuit boards.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia N70 Display Replacement: adım 10, 3 resimden 1. Nokia N70 Display Replacement: adım 10, 3 resimden 2. Nokia N70 Display Replacement: adım 10, 3 resimden 3.
    • While pulling back each of the clamps marked in the image, lift out each side of the screen independently.
    • Be careful when using the plastic prying tool to not scratch the display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Justin
1.026 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Regan Fall 2011 Cal Poly, Team 6-2, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G2
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 58
Her zaman: 9,570
