Ana içeriğe geç
Nokia N70 Keypad Replacement
Neye ihtiyacın var
  1. Nokia N70 Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Keypad Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Keypad Replacement: adım 3, 1 resimden 1.
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Keypad Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the phone.
  5. Nokia N70 Keypad Replacement, Keypad: adım 5, 3 resimden 1. Nokia N70 Keypad Replacement, Keypad: adım 5, 3 resimden 2. Nokia N70 Keypad Replacement, Keypad: adım 5, 3 resimden 3.
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Keypad Replacement: adım 6, 3 resimden 1. Nokia N70 Keypad Replacement: adım 6, 3 resimden 2. Nokia N70 Keypad Replacement: adım 6, 3 resimden 3.
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
Sonuç
Justin
984 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Regan Fall 2011 Cal Poly, Team 6-2, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G2
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 4,025
