Ana içeriğe geç
Nokia N9 Battery Replacement
Neye ihtiyacın var
  1. Nokia N9 Battery Replacement, remove top parts: adım 1, 3 resimden 1. Nokia N9 Battery Replacement, remove top parts: adım 1, 3 resimden 2. Nokia N9 Battery Replacement, remove top parts: adım 1, 3 resimden 3.
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. Nokia N9 Battery Replacement, loosen the screen: adım 2, 3 resimden 1. Nokia N9 Battery Replacement, loosen the screen: adım 2, 3 resimden 2. Nokia N9 Battery Replacement, loosen the screen: adım 2, 3 resimden 3.
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. Nokia N9 Battery Replacement, disconnect screen from phone: adım 3, 3 resimden 1. Nokia N9 Battery Replacement, disconnect screen from phone: adım 3, 3 resimden 2. Nokia N9 Battery Replacement, disconnect screen from phone: adım 3, 3 resimden 3.
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
  4. Nokia N9 Battery Replacement, remove screws: adım 4, 1 resimden 1.
    • Unscrew the marked screws using the T4 torx screwdriver.
  5. Nokia N9 Battery Replacement, remove covering: adım 5, 2 resimden 1. Nokia N9 Battery Replacement, remove covering: adım 5, 2 resimden 2.
    • You will see a strip holding the larger battery cover in place at one side.
    • Rotate the strip a quarter turn along the long axis, and lift it out.
    • Use the opening tool to lift the battery cover up and out.
  6. Nokia N9 Battery Replacement, replace the battery: adım 6, 2 resimden 1. Nokia N9 Battery Replacement, replace the battery: adım 6, 2 resimden 2.
    • Click open the battery connector from beneath the connector.
    • Lift the battery from the phone and replace it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
knipwim
11.403 İtibar
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 70
Her zaman: 3,130
