Ana içeriğe geç
Nokia N900 Camera Replacement
Neye ihtiyacın var
  1. Nokia N900 Camera Replacement, Camera: adım 1, 1 resimden 1.
    • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia N900 Camera Replacement: adım 2, 1 resimden 1.
    • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia N900 Camera Replacement: adım 3, 1 resimden 1.
    • Remove the battery
    FixBot'a Sor
    Yorum Ekle
  4. Nokia N900 Camera Replacement: adım 4, 1 resimden 1.
    • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
    • Camera
    FixBot'a Sor
    Yorum Ekle
  5. Nokia N900 Camera Replacement: adım 5, 1 resimden 1.
    • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
    • The camera is located on the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia N900 Camera Replacement: adım 6, 1 resimden 1.
    • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
    • Back side of the phone where the camera is located
    FixBot'a Sor
    Yorum Ekle
  7. Nokia N900 Camera Replacement: adım 7, 1 resimden 1.
    • Here are the two main pieces of the camera.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia N900 Camera Replacement: adım 8, 1 resimden 1.
    • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Juan Haro
284 İtibar
2 adet Kılavuz yazıldı
Ekip
New Mexico State, Team 1-4, Easley Spring 2014 New Mexico State, Team 1-4, Easley Spring 2014 üyesi
NMSU-EASLEY-S14S1G4
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Where to find a camera part ?
Thanks
François Soltic - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,566
