Ana içeriğe geç
Nokia N900 Slider Assembly Replacement
Neye ihtiyacın var
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: adım 1, 1 resimden 1.
    • Turn the phone over so the screen is face down.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia N900 Slider Assembly Replacement: adım 2, 2 resimden 1. Nokia N900 Slider Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia N900 Slider Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the battery by lifting it out of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia N900 Slider Assembly Replacement: adım 4, 2 resimden 1. Nokia N900 Slider Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
    FixBot'a Sor
    Yorum Ekle
  5. Nokia N900 Slider Assembly Replacement: adım 5, 1 resimden 1.
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Troy Posey
349 İtibar
2 adet Kılavuz yazıldı
Ekip
New Mexico State, Team 1-4, Easley Spring 2014 New Mexico State, Team 1-4, Easley Spring 2014 üyesi
NMSU-EASLEY-S14S1G4
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 1,225
