Ana içeriğe geç
Nokia N900 USB Replacement
Neye ihtiyacın var
  1. Nokia N900 USB Replacement, USB: adım 1, 1 resimden 1.
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: adım 2, 2 resimden 1. Nokia N900 USB Replacement: adım 2, 2 resimden 2.
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: adım 3, 1 resimden 1.
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: adım 4, 2 resimden 1. Nokia N900 USB Replacement: adım 4, 2 resimden 2.
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: adım 5, 1 resimden 1.
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: adım 6, 1 resimden 1.
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: adım 7, 1 resimden 1.
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: adım 8, 1 resimden 1.
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Troy Posey
349 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 2,597
