Ana içeriğe geç
Nokia X Display Assembly Replacement
Neye ihtiyacın var
  1. Nokia X Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia X Display Assembly Replacement: adım 2, 1 resimden 1.
    • To remove the battery, simply use your finger to pry the battery out of its slot.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia X Display Assembly Replacement: adım 3, 1 resimden 1.
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia X Display Assembly Replacement, Display Assembly: adım 4, 2 resimden 1. Nokia X Display Assembly Replacement, Display Assembly: adım 4, 2 resimden 2.
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia X Display Assembly Replacement: adım 5, 2 resimden 1. Nokia X Display Assembly Replacement: adım 5, 2 resimden 2.
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia X Display Assembly Replacement: adım 6, 1 resimden 1.
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
    FixBot'a Sor
    Yorum Ekle
Sonuç
29 farklı kişi bu kılavuzu tamamladı.
Avery Dorsey
1.894 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-1, Brown Winter 2015 USF Tampa, Team 6-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G1
3 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 6,365
