Aletler
Parçalar
Hiçbir parça belirtilmedi.
The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
Using the flat end of the spudger tool, unhook the two connectors connecting the audio jack to the motherboard.
The top connecter is attached via an adhesive as well, it will require a little bit of force to remove it.
11 farklı kişi bu kılavuzu tamamladı.
