Giriş
Is your Nokia X unable to connect to a USB charger? This guide will shows how to replace a faulty USB port.
Parçalar
Hiçbir parça belirtilmedi.
Remove the back cover of the device by applying light pressure toward the outer rim and display.
Using the spudger tool, release the top flex ribbon from the light swap package.
Again, using a spudger tool, release the rear facing camera from the light swap display.
Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
4 farklı kişi bu kılavuzu tamamladı.
