Ana içeriğe geç
Nokia XL Dual SIM Disassembly
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Nokia XL Dual SIM Disassembly, Back Cover Removal: adım 1, 1 resimden 1.
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia XL Dual SIM Disassembly, Battery Removal: adım 2, 2 resimden 1. Nokia XL Dual SIM Disassembly, Battery Removal: adım 2, 2 resimden 2.
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia XL Dual SIM Disassembly, Screen Separation part 1: adım 3, 2 resimden 1. Nokia XL Dual SIM Disassembly, Screen Separation part 1: adım 3, 2 resimden 2.
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia XL Dual SIM Disassembly, Screen Separation part 2: adım 4, 3 resimden 1. Nokia XL Dual SIM Disassembly, Screen Separation part 2: adım 4, 3 resimden 2. Nokia XL Dual SIM Disassembly, Screen Separation part 2: adım 4, 3 resimden 3.
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia XL Dual SIM Disassembly, System components: adım 5, 1 resimden 1.
    • Once the device is open, take note of all the components.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shadeed Bilal
231 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G4
3 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 469
