Ana içeriğe geç
Nokia XL Dual Sim Rear Camera Replacement
Neye ihtiyacın var
  1. Nokia XL Dual Sim Rear Camera Replacement, Back Cover Removal: adım 1, 1 resimden 1.
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: adım 2, 2 resimden 1. Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: adım 2, 2 resimden 2.
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: adım 3, 2 resimden 1. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: adım 3, 2 resimden 2.
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: adım 4, 3 resimden 1. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: adım 4, 3 resimden 2. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: adım 4, 3 resimden 3.
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Rear Camera Replacement, System components: adım 5, 1 resimden 1.
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: adım 6, 2 resimden 1. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • With tweezers, gently release the rear camera motherboard connector.
  7. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: adım 7, 3 resimden 1. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: adım 7, 3 resimden 2. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: adım 7, 3 resimden 3.
    • Gently pull the motherboard connector upward to remove the rear camera component.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shadeed Bilal
231 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G4
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 778
