Ana içeriğe geç
Nook BNRV300 Battery Replacement
Neye ihtiyacın var
  1. Nook BNRV300 Battery Replacement, Power Button: adım 1, 3 resimden 1. Nook BNRV300 Battery Replacement, Power Button: adım 1, 3 resimden 2. Nook BNRV300 Battery Replacement, Power Button: adım 1, 3 resimden 3.
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
    FixBot'a Sor
    Yorum Ekle
  2. Nook BNRV300 Battery Replacement: adım 2, 1 resimden 1.
    • Using your fingers, take off the power button.
    FixBot'a Sor
    Yorum Ekle
  3. Nook BNRV300 Battery Replacement, Back Cover: adım 3, 3 resimden 1. Nook BNRV300 Battery Replacement, Back Cover: adım 3, 3 resimden 2. Nook BNRV300 Battery Replacement, Back Cover: adım 3, 3 resimden 3.
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nook BNRV300 Battery Replacement: adım 4, 1 resimden 1.
    • Slide the back cover down towards the USB port to release the back cover.
    • The pictures show the case being pried open, but do not do this unless it is necessary.
    FixBot'a Sor
    Yorum Ekle
  5. Nook BNRV300 Battery Replacement: adım 5, 3 resimden 1. Nook BNRV300 Battery Replacement: adım 5, 3 resimden 2. Nook BNRV300 Battery Replacement: adım 5, 3 resimden 3.
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
    FixBot'a Sor
    Yorum Ekle
  6. Nook BNRV300 Battery Replacement: adım 6, 2 resimden 1. Nook BNRV300 Battery Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
    FixBot'a Sor
    Yorum Ekle
  7. Nook BNRV300 Battery Replacement, Battery: adım 7, 3 resimden 1. Nook BNRV300 Battery Replacement, Battery: adım 7, 3 resimden 2. Nook BNRV300 Battery Replacement, Battery: adım 7, 3 resimden 3.
    • The battery is located on the inside back cover of the Nook.
    • Do not use metal tools when prying up the battery. This may puncture the battery and cause harm to you and/or your device.
    • Insert a nylon spudger beneath the clear plastic adhesive holding the battery to the back cover.
    • Work around the battery, peeling up all of the adhesive.
    FixBot'a Sor
    Yorum Ekle
  8. Nook BNRV300 Battery Replacement: adım 8, 2 resimden 1. Nook BNRV300 Battery Replacement: adım 8, 2 resimden 2.
    • Hold on to one of the adhesive tabs and pull up.
    • This will fully remove the battery from its compartment.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 85
Her zaman: 4,959
