Ana içeriğe geç
Nook BNRV300 Display Replacement
Neye ihtiyacın var
  1. Nook BNRV300 Display Replacement, Power Button: adım 1, 3 resimden 1. Nook BNRV300 Display Replacement, Power Button: adım 1, 3 resimden 2. Nook BNRV300 Display Replacement, Power Button: adım 1, 3 resimden 3.
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
    FixBot'a Sor
    Yorum Ekle
  2. Nook BNRV300 Display Replacement: adım 2, 1 resimden 1.
    • Using your fingers, take off the power button.
    FixBot'a Sor
    Yorum Ekle
  3. Nook BNRV300 Display Replacement, Back Cover: adım 3, 3 resimden 1. Nook BNRV300 Display Replacement, Back Cover: adım 3, 3 resimden 2. Nook BNRV300 Display Replacement, Back Cover: adım 3, 3 resimden 3.
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nook BNRV300 Display Replacement: adım 4, 1 resimden 1.
    • Slide the back cover down towards the USB port to release the back cover.
    • The pictures show the case being pried open, but do not do this unless it is necessary.
    FixBot'a Sor
    Yorum Ekle
  5. Nook BNRV300 Display Replacement: adım 5, 3 resimden 1. Nook BNRV300 Display Replacement: adım 5, 3 resimden 2. Nook BNRV300 Display Replacement: adım 5, 3 resimden 3.
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
    FixBot'a Sor
    Yorum Ekle
  6. Nook BNRV300 Display Replacement: adım 6, 2 resimden 1. Nook BNRV300 Display Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
    FixBot'a Sor
    Yorum Ekle
  7. Nook BNRV300 Display Replacement, Motherboard: adım 7, 2 resimden 1. Nook BNRV300 Display Replacement, Motherboard: adım 7, 2 resimden 2.
    • Use an anti-static mat to prevent electric shock from damaging the motherboard and its components. Be careful when using metal tools on your device.
    • Using a T5 Torx screwdriver, remove the eleven 3mm screws.
    FixBot'a Sor
    Yorum Ekle
  8. Nook BNRV300 Display Replacement: adım 8, 3 resimden 1. Nook BNRV300 Display Replacement: adım 8, 3 resimden 2. Nook BNRV300 Display Replacement: adım 8, 3 resimden 3.
    • Place the spudger through the loop of the display cable. Lift the tool up, which will unhook the display cable.
    • Do not put force on the motherboard with the spudger. This could damage components on the motherboard.
    • Using your fingers, lift up the display cable.
    FixBot'a Sor
    Yorum Ekle
  9. Nook BNRV300 Display Replacement: adım 9, 1 resimden 1.
    • Using your fingers, gently lift the motherboard from the display.
    FixBot'a Sor
    Yorum Ekle
  10. Nook BNRV300 Display Replacement, Display: adım 10, 3 resimden 1. Nook BNRV300 Display Replacement, Display: adım 10, 3 resimden 2. Nook BNRV300 Display Replacement, Display: adım 10, 3 resimden 3.
    • Insert a nylon spudger between the display's metal backing and the front cover plastic.
    • Gently pry the display away from the front cover by moving the spudger up and down.
    • During reassembly, align the small black plastic peg at the bottom right of the plastic frame with the inner hole at the bottom right of the metal display backing.
    FixBot'a Sor
    Yorum Ekle
  11. Nook BNRV300 Display Replacement: adım 11, 2 resimden 1. Nook BNRV300 Display Replacement: adım 11, 2 resimden 2.
    • Press down on the fastener tab with your finger.
    FixBot'a Sor
    Yorum Ekle
  12. Nook BNRV300 Display Replacement: adım 12, 2 resimden 1. Nook BNRV300 Display Replacement: adım 12, 2 resimden 2.
    • The display cracks very easily. If this happens, there will be glass shards that could potentially cause injury. You may want to wear protection for hands and eyes while completing this step.
    • Insert a nylon spudger between the plastic frame on the display and the metal casing on the display.
    • Gently pry the display away from the plastic frame. Place the display on a hard, flat surface to support it when prying it off the metal backing. The screen may crack anyway.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
Was all good till I got here:
The display was glued to the metal backing. Needs something to heat up the adhesive in order to remove it.
Joseph W Charpentier - Yanıt Paylaş
Hi. What display model should I look for? Is this one ED060SC7 good?
pogo79 - Yanıt Paylaş
I'm looking in the Aliexp... store and I don't know what display to choose .
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Yanıt Paylaş
Appreciate the feedback!
Emily Tracy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 58
Her zaman: 3,592
