Ana içeriğe geç
Nook BNRV300 Power Button Replacement
Neye ihtiyacın var
  1. Nook BNRV300 Power Button Replacement, Power Button: adım 1, 3 resimden 1. Nook BNRV300 Power Button Replacement, Power Button: adım 1, 3 resimden 2. Nook BNRV300 Power Button Replacement, Power Button: adım 1, 3 resimden 3.
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
    FixBot'a Sor
    Yorum Ekle
  2. Nook BNRV300 Power Button Replacement: adım 2, 1 resimden 1.
    • Using your fingers, take off the power button.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2Kılavuz Yorumları
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Yanıt Paylaş
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 1,400
