Ana içeriğe geç
Nook Color Battery Replacement
Neye ihtiyacın var
    1. Nook Color Battery Replacement, Back Cover: adım 1, 2 resimden 1. Nook Color Battery Replacement, Back Cover: adım 1, 2 resimden 2.
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Battery Replacement: adım 2, 2 resimden 1. Nook Color Battery Replacement: adım 2, 2 resimden 2.
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Color Battery Replacement, Front Cover: adım 3, 1 resimden 1.
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Battery Replacement: adım 4, 2 resimden 1. Nook Color Battery Replacement: adım 4, 2 resimden 2.
      • Pry off the front panel using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Nook Color Battery Replacement: adım 5, 2 resimden 1. Nook Color Battery Replacement: adım 5, 2 resimden 2.
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Color Battery Replacement, Battery: adım 6, 2 resimden 1. Nook Color Battery Replacement, Battery: adım 6, 2 resimden 2.
      • Remove the tape which holds the wiring to the battery using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Battery Replacement: adım 7, 3 resimden 1. Nook Color Battery Replacement: adım 7, 3 resimden 2. Nook Color Battery Replacement: adım 7, 3 resimden 3.
      • On the back side of the middle panel, pry the battery using the plastic opening tools.
      • Use of force is necessary since the battery is glued down.
      FixBot'a Sor
      Yorum Ekle
    3. Nook Color Battery Replacement: adım 8, 2 resimden 1. Nook Color Battery Replacement: adım 8, 2 resimden 2.
      • Slide the connecting wire through the opening of where the battery was placed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
John Goly
529 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G5
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 51
Her zaman: 3,627
