Giriş
While removing faulty or damaged buttons, use caution as the buttons may fall out of place while removing the back panel. If buttons do not fall out, a little bit of force will be required in pulling them out of place.
Neye ihtiyacın var
Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
Once you have removed both the back and front panels of the device, you will isolate the panel which contains the buttons. You will remove the volume buttons on the top right first. Use some force upwards and the button will slide free.
2 farklı kişi bu kılavuzu tamamladı.
