Ana içeriğe geç
Nook Color Buttons Replacement
Neye ihtiyacın var
  1. Nook Color Buttons Replacement, Back Cover: adım 1, 2 resimden 1. Nook Color Buttons Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Nook Color Buttons Replacement: adım 2, 2 resimden 1. Nook Color Buttons Replacement: adım 2, 2 resimden 2.
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
    FixBot'a Sor
    Yorum Ekle
  3. Nook Color Buttons Replacement, Front Cover: adım 3, 1 resimden 1.
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nook Color Buttons Replacement: adım 4, 2 resimden 1. Nook Color Buttons Replacement: adım 4, 2 resimden 2.
    • Pry off the front panel using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. Nook Color Buttons Replacement: adım 5, 2 resimden 1. Nook Color Buttons Replacement: adım 5, 2 resimden 2.
    • Lift up on the connectors to disconnect them using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. Nook Color Buttons Replacement, Buttons: adım 6, 3 resimden 1. Nook Color Buttons Replacement, Buttons: adım 6, 3 resimden 2. Nook Color Buttons Replacement, Buttons: adım 6, 3 resimden 3.
    • Once you have removed both the back and front panels of the device, you will isolate the panel which contains the buttons. You will remove the volume buttons on the top right first. Use some force upwards and the button will slide free.
    FixBot'a Sor
    Yorum Ekle
  7. Nook Color Buttons Replacement: adım 7, 3 resimden 1. Nook Color Buttons Replacement: adım 7, 3 resimden 2. Nook Color Buttons Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Next, you will remove the power button from the top left of the middle portion of your device. Using tweezers you will carefully lift the button from where it sits and remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Goly
529 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G5
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 1,165
