Ana içeriğe geç
Nook Color Display Replacement
Neye ihtiyacın var
  1. Nook Color Display Replacement, Back Cover: adım 1, 2 resimden 1. Nook Color Display Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Nook Color Display Replacement: adım 2, 2 resimden 1. Nook Color Display Replacement: adım 2, 2 resimden 2.
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
    FixBot'a Sor
    Yorum Ekle
  3. Nook Color Display Replacement, Front Cover: adım 3, 1 resimden 1.
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nook Color Display Replacement: adım 4, 2 resimden 1. Nook Color Display Replacement: adım 4, 2 resimden 2.
    • Pry off the front panel using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. Nook Color Display Replacement: adım 5, 2 resimden 1. Nook Color Display Replacement: adım 5, 2 resimden 2.
    • Lift up on the connectors to disconnect them using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. Nook Color Display Replacement, Motherboard: adım 6, 3 resimden 1. Nook Color Display Replacement, Motherboard: adım 6, 3 resimden 2. Nook Color Display Replacement, Motherboard: adım 6, 3 resimden 3.
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Nook Color Display Replacement: adım 7, 1 resimden 1.
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Nook Color Display Replacement: adım 8, 2 resimden 1. Nook Color Display Replacement: adım 8, 2 resimden 2.
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
    FixBot'a Sor
    Yorum Ekle
  9. Nook Color Display Replacement, Display: adım 9, 3 resimden 1. Nook Color Display Replacement, Display: adım 9, 3 resimden 2. Nook Color Display Replacement, Display: adım 9, 3 resimden 3.
    • Use a plastic opening tool to gently pry the display upwards.
    • Lift the display out with your hands until the display has separated from the frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Matthew Perdomo
509 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G5
3 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
this site doesn't sell the Nook Color display. Where did you get yours?
Suzette Garoutte - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 63
Her zaman: 4,364
