Ana içeriğe geç
Nook Color Motherboard Replacement
Neye ihtiyacın var
  1. Nook Color Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Nook Color Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Motherboard Replacement: adım 2, 2 resimden 1. Nook Color Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Motherboard Replacement, Front Cover: adım 3, 1 resimden 1.
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Motherboard Replacement: adım 4, 2 resimden 1. Nook Color Motherboard Replacement: adım 4, 2 resimden 2.
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Motherboard Replacement: adım 5, 2 resimden 1. Nook Color Motherboard Replacement: adım 5, 2 resimden 2.
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Nook Color Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Nook Color Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
  7. Nook Color Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
  8. Nook Color Motherboard Replacement: adım 8, 2 resimden 1. Nook Color Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Perdomo
497 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G5
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,159
