Ana içeriğe geç
Nook Color Motherboard Replacement
Neye ihtiyacın var
    1. Nook Color Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Nook Color Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Motherboard Replacement: adım 2, 2 resimden 1. Nook Color Motherboard Replacement: adım 2, 2 resimden 2.
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Color Motherboard Replacement, Front Cover: adım 3, 1 resimden 1.
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Motherboard Replacement: adım 4, 2 resimden 1. Nook Color Motherboard Replacement: adım 4, 2 resimden 2.
      • Pry off the front panel using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Nook Color Motherboard Replacement: adım 5, 2 resimden 1. Nook Color Motherboard Replacement: adım 5, 2 resimden 2.
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Color Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Nook Color Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Nook Color Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
      • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Motherboard Replacement: adım 7, 1 resimden 1.
      • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Nook Color Motherboard Replacement: adım 8, 2 resimden 1. Nook Color Motherboard Replacement: adım 8, 2 resimden 2.
      • Lift the motherboard gently from the side with the larger connector ribbon.
      • Slide the white cable gently from underneath its holding place to free the motherboard completely.
      • Remove the motherboard carefully from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Perdomo
509 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G5
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 1,440
