Ana içeriğe geç
Nook Color Speaker Replacement
Neye ihtiyacın var
    1. Nook Color Speaker Replacement, Back Cover: adım 1, 2 resimden 1. Nook Color Speaker Replacement, Back Cover: adım 1, 2 resimden 2.
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Speaker Replacement: adım 2, 2 resimden 1. Nook Color Speaker Replacement: adım 2, 2 resimden 2.
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Color Speaker Replacement, Front Cover: adım 3, 1 resimden 1.
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Speaker Replacement: adım 4, 2 resimden 1. Nook Color Speaker Replacement: adım 4, 2 resimden 2.
      • Pry off the front panel using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Nook Color Speaker Replacement: adım 5, 2 resimden 1. Nook Color Speaker Replacement: adım 5, 2 resimden 2.
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Color Speaker Replacement, Speaker: adım 6, 2 resimden 1. Nook Color Speaker Replacement, Speaker: adım 6, 2 resimden 2.
      • Remove the protective lining located above the speaker.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Color Speaker Replacement: adım 7, 3 resimden 1. Nook Color Speaker Replacement: adım 7, 3 resimden 2. Nook Color Speaker Replacement: adım 7, 3 resimden 3.
      • Using a plastic opening tool, push on the speaker from the front of the panel to loosen the speaker. Some force will be required. Once loose, use your index finger to push it through.
      FixBot'a Sor
      Yorum Ekle
    3. Nook Color Speaker Replacement: adım 8, 1 resimden 1.
      • Once pressed all the way through, the speaker will be loose and free to replace.
      FixBot'a Sor
      Yorum Ekle
Sonuç
John Goly
529 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G5
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 601
