Giriş
This replacement guide for the Nook HD+ requires the use of a soldering iron which should not be used by children, and if mishandled could lead to extreme injury.
  1. Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit. Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Carefully remove the center chassis from the bottom frame. Carefully remove the center chassis from the bottom frame.
    • Carefully remove the center chassis from the bottom frame.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard.
    • Detach the battery ribbon from the motherboard.
  6. Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  7. Remove the wire from the attachment on the motherboard (this wire un-clips). Remove the wire from the attachment on the motherboard (this wire un-clips).
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  8. Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten. Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  9. Replace new antenna following all the steps in reverse. Replace new antenna following all the steps in reverse.
    • Replace new antenna following all the steps in reverse.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elijah Gonsalves
914 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 6
Son 30 Gün: 14
Her zaman: 760
