Giriş
This guide will show you how to remove and replace the cover of your Nook HD+.
Parçalar
Hiçbir parçaya gerek yok.
  1. Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame. Note there will be glue and be careful not to brake the clips. Note there will be glue and be careful not to brake the clips.
    • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
      • Note there will be glue and be careful not to brake the clips.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Apply glue round the inside perimeter of the new frame on the clip side.
    • Apply glue round the inside perimeter of the new frame on the clip side.
  4. Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
      • Run finger around the entire frame making sure all the clips are in place.
      • Let glue dry.
Sonuç
Alex Pelicas
259 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 4
Her zaman: 544
